XR 100
  • 04250r
    XR 100
    by 04250r » Fri Feb 10, 2012 9:28 pm
    I have a 2003 xr 100 and was wondering where the cam tensioner is located and how to take the cam shaft off!
    Just a meat head looking for advice
    Their aint no such thing as riding hard if you aint wrecking harder...
  • Hondacrfrider
    by Hondacrfrider » Fri Mar 09, 2012 3:24 pm
    look in the manual
    Bikes in order
    -2009 crf150f (sold)
    -2008 crf230f (sold)
    -2008 crf250x (Dad's bike)(sold)
    -2008 ktm 144sx (mine, sold)
    -2009 crf100f (sister's bike)
    -2012 crf250r (mine)
    -2012 crf250r (dad's)
    by crfsonly » Fri Mar 09, 2012 5:37 pm
    i wouldn't recommend doing this kind of work without a service manual. you'll also need torque specs as well as other information to get the timing correct, etc. the cam chain tensioner is spring loaded and automatically adjusts when the adjusting bolt is loosened. the adjuster bolt is located at the bottom left of the cylinder. to remove the cam, you'll have to loosen this adjuster bolt and then using a screw driver pushing the cam chain tensioner with a screwdriver, then tighten then tighten the bolt and lock nut. remove the cam sprocket bolt, turn the crankshaft counterclockwise one full turn (360 degrees) and remove the second cam sprocket bolt. remove the cam chain from the sprocket and remove the cam sprocket. use some wire to keep the cam chain from falling into the crankcase. remove the four cam holder nuts and washer and remove the cam holder. remove the cam shaft.
    again, you'll need a manual to reinstall it.
    Clymer:
    http://www.crfsonly.com/catalog/product ... ts_id/4332
    Honda:
    http://www.crfsonly.com/catalog/product ... ts_id/3226
